Hi, I have an RR5 2006 I have fitted a power commander 3 and also incorrectly bought an 08 Power Commander ignition module in error, the 06 version does not seem to come up on eBay that often. Not sure if this has been done before, but I am going to try and fit the 08 module, as far as I can tell it is only the ignition loom plug that is different, and where the plugs are located left side and under tank. Both loom plugs are 6 pin. If I remove the plugs from the bike loom and replace with 08 plugs to fit the Ignition module does anyone think this might work? Guessing I should be able to find an 06 and 08 wiring diagram for electrics to pin out correctly.
