Power Commander III \ V
Discussion in 'Mods, Upgrades, Accessories and Products' started by samuk, May 18, 2012.
  1. samuk
    samuk Well-Known Member
    Hi,
    what is the difference bettwen version III and Version V?
    they both are listed for the RR4 \ RR5 - or is that incorrect?
    thanks
  2. garyauk
    garyauk Active Member
    Power Commander V is much smaller, and you can do more with it
  3. samuk
  4. samuk
    Okay so is the V, more difficult to use? or similar to the III?
  5. ray
    ray Well-Known Member
    I think Dynojet may have discontinued the III for the 04-07.
    The V is a better unit
    So much smaller, you can wire a switch straight into it to switch between maps, if you have a probe in your exhaust you can use the Autotune, plug n play quickshifter (never be as good as the HM though).
  6. JM1
    JM1 Active Member
    V is smaller and has powered USB
  7. samuk
    I got a full race system on my 04...will that be an issue? as there are no Cats?
    also fitting wise - is the V the same as III?
  8. JM1
    JM1 Active Member
    They are the same thing essentially. Fitting process is the same. The PC can be setup with a map which suits the mods your bike has. This means you need to either find a map that suits your mods or have a custom map made by a tuner.
