Hi all, Need a map for a 2009 CBR100rr, has a Yoshimura R77 slip-on, K&N filter, using a PC3 usb, but can convert a PCV map. Fitting it today as taking tank off to fit a HM quickshifter, then two jobs done at once. Looked at the maps on the Dynojet website and all look so different ?? for the same spec and set-up. I know each bike will have a slightly different map as no two will be dead on the same, but so different. Rather have a custom map if poss off a fellow user to know it's nearer til it's on the dyno. Thanks in advance.
I have a custom map on my PCV you can have, mine is a 2008 ,same spec as yours I haven't got a lap top so you would need to pop round Pm me if you are interested
Cheers Clarkey, I have to do that, when I get time to pop over I'll P'm you to see if it's convient for you too. Top man.
Hi Paul, I have custom map for a 09 blade with YOSHI r77 slip on,O2 eliminator,BMC air filter .had it when I was using a YOSHI .send me a pm with your email and I will send.BRI
