Power commander map sharing
Discussion in 'General 1000RR Discussion' started by BladeJogger, Aug 10, 2015.
  1. BladeJogger
    BladeJogger Member
    Hi Guys,
    I have a pc5 fitted to my bike,it has been custom setup.Does anybody know how I go about sharing the map for another forum member to use on his bike?
    Thanks
  2. Mattie1972
    Mattie1972 Active Member
    Morning, when i had a custom map done on my old Tuono i asked the dyno place to give me a copy of the file on a memory stick as back up. You could ask your dyno place if they have a copy of your map file.
    My PCiii came with a USB cable so you could plug a laptop directly into it (and look like a Moto GP engineer). If you have a laptop and USB cable, you should be able to connect directly to the PCv and save the file to your laptop. From there you can just email it, they are not huge files.
  3. BladeJogger
    BladeJogger Member
    Ok,thanks Mattie,I know the dyno guy kept a copy of it,I do have a lap top and cable so will give it a go.
