2004 1000rr I've had power commander 3 and a micron pipe in the shed for best part of a year bought of eBay got round to fitting them this weekend and the bike don't start no more. When I turn the ignition on the pc green display cycles but the fuel pump doesn't cycle so no start removed the pc and the pump cycles and the bike cracks up 1st turn over as usual replaced pc an no fuel pump and no start question is the pc knackered, it's too late now to return if it is So is it repairable or do I just sling it in the bin and buy another ?
That was my 1st thought Arthur I did make sure the contacts were polished and clean, but the pc is lighting up and cycling up and down in time to the rev counter sweep when the ignition is turned on then showing 1geen bar. So I presumed that the earth was good I'll double check the connection again tomorrow
