Power commander V Issue?
Discussion in 'Mods, Upgrades, Accessories and Products' started by bandit_287, Mar 31, 2015.
  1. bandit_287
    bandit_287 Active Member
    Second hand Power commander V just fitted to a friends 11 plate Blade, all connected up accordingly, bike fires up and runs fine( not been out for a blast as the weather is shite ) but revs up and idles fine. The power light is illuminated green when the bike's running but the status light is not illuminated at all.
    Houston do we have a problem?
  2. Garyb
    Garyb Moderator.
    No map installed?
  3. bandit_287
    It apparently has a map from the previous owner but it's not the correct one for my friends bike.
  4. sinewave
    Does this 'Friend' have the Clap too? ;)
  5. Womblewizard
    Womblewizard Active Member
    Does the status light come on? I'm sure the power light on mine goes green when running but no status light, thought this only comes on when connected to laptop!
  6. bandit_287
    Yes the status light flashes red when the ignition is on and bike not running, then goes out when we fire it up. Sounds like it's doing what it's supposed to be then. He's going to download and install a map tomorrow and see what happens.
  7. Barstewardsquad
    Connect a laptop and run the engine. You'll soon see if it is reading the throttle etc
  8. bandit_287
    Will do, we've got to borrow a laptop off someone, we'll do it today.
    Thanks for the help.
  9. Emywmpb
    Emywmpb Active Member
    Dynojet website states that the status light should NOT be on when the bike is running. If it was lit, there would be a problem.
    The ON light should be green as soon as the key is turned.
