Power Supply to Iphone 5
Discussion in 'Mods, Upgrades, Accessories and Products' started by ReadyAimFIRE, Mar 19, 2014.
  1. ReadyAimFIRE
    ReadyAimFIRE New Member
    Morning all.....
    I'd like to wire in a charge cable for my Iphone 5 so I can use it as a GPS Navigation aid when its fitted to my bike....
    I already have a extension cable coming off the battery to a quick connector under the rear seat cowl for a Optimate 4 battery charger so would make sense to use the socket there if I could
    Does anyone have any experience with this at all?
    Cheers
    Wilko
  2. Si.
  3. ReadyAimFIRE
    Perfect Si :)
    Just ordered both.......
  4. Cookie42
    Cookie42 Active Member
    That is a superb bit of kit. Thanks for sharing.
  5. Si.
    No probs.
  6. Bloy182
    Bloy182 Active Member
  7. lukecairns
    lukecairns New Member
    They are brilliant ... I had one on my 600rr ! Need to put one on my 1000rr for assen in june
  8. The.kickboxer
    The.kickboxer Active Member
    Also going to Assen in June. What ferry you on?
  9. lukecairns
    Shuttle from folkstone at 6/6:30 am mate on the Friday so have a day riding through Netherlands etc
  10. sinewave
    You can buy a genuine Optimate Waterproof USB lead which plugs straight in to your existing charger outlet connection.
    Got mine routed to the Dash area so anything I want to plug in is no probs as all kit from any OEM always comes with a USB nowadays.
    Fag lighter connections are history now.
    O-102 SAE USB Charger Lead
  11. The.kickboxer
  12. lukecairns
    When you going?
