Do you have the manual that came with the bike? Mine was all messed up so I put it back to stock using the settings from the manual (I have 2013 so manual may have different info)
Sorry,I didn't explain that well. I recently serviced my forks and when I put them back together was messing with preload adjuster. I counted 15 full turns from soft to hard (stop to stop) I'm sure there is only meant to be 10 turns? If someone could count there's stop to stop just to make sure. There is nothing in manual or Haynes about how many turns there should be. Hope this makes a bit more sense
