Hi guys, My quick shifter has stopped working! Well almost. It's very hard to press the lever down and sometimes doesn't even let me, I have to use clutch. I have to use real force and it eventually clunks! Just seems to work when it wants lol. Ran it through the box on front and rear paddock stand and it changes as it should, but under load it doesn't! What could it be? I did have an off on track but it only slid on the right hand slide of the bike.
Press the lever down?? Are you using reverse shift pattern as you can only use the Shifter up the box. Try HM otherwise for a new strain gauge.
