puncture repair kit
Discussion in 'Maintenance' started by bonjo, Jul 7, 2019.
  1. bonjo
    bonjo Active Member
    any recommendation for a repair kit that I can use for car and bike tyres from the outside?
    My only experience is of one where a rope like plug is inserted and the seal was not very (maybe the person who did it) and will be looking art the mushroom style plugs
    :confused:
  2. tony sawyer
    tony sawyer New Member
    you can get a tapered plastic key type of thing that you twist straight into tyre after you remove the cause of problem and then just snap key off you will find one on the net the are very handy to just put in your pocket trouble is I have forgot the name of the them
  3. Bikeboy
    Bikeboy Active Member
    Theres a kit called stop n go .it has mushroom type bungs ..use for car and bike. Amazon and Ebay etc
  4. bonjo
    bonjo Active Member
    I think it will have to be stop & go. Checked dynaplug; it doesn't seem to do cars.
  5. hitch
    hitch Elite Member
    Works on cars...
  6. Spygoat
    Spygoat Well-Known Member
    That Dynaplug kit is absolute crap. I had one and tossed it into the trash after it failed in an emergency on the SP. I got a Slime kit from Amazon with a CO2 inflation device (takes the small airgun cartridges) and regular rope type plugs. I've used it once on the SP and once on a friends R1. No issues. It takes 2-3 of the cartridges to get a tire almost fully inflated. It defo gets you full enough to get to a service station and an air machine.
    https://www.amazon.com/Slime-20240-...way&sprefix=motorcycle+tire+pl,aps,129&sr=8-4
    • Useful Useful x 2
  7. Spygoat
    Also, you can buy the screw in air cartridges from Amazon on the cheap. They do not have to be the "Slime" brand air carts.
