Putting a 954 on a diet.
Discussion in 'Mods, Upgrades, Accessories and Products' started by Juggler87, Feb 22, 2014.
  1. Juggler87
    Juggler87 New Member
    Okay, ideally it would include carbon wheels and titanium everything. Budget needless to say wouldn't possibly allow. Am I right in thinking that I should be trying to remove mass from rotational masses and unsprung weight first? I see titanium exhausts come up second hand at reasonable prices, but that is neither of the above. Ideally I want to upgrade as things need replacing, caliper bolts and chain have seen better days. I'm no pro racer so perhaps looking at mechanially sympathetic mods.
    What should I looking at?
    Alu/titanium bolts for the discs and calipers
    Chain and sprockets
    Penny for your thoughts (unless you're going to tell me to save myself a fortune and cut back on the chips).
  2. fez.57
    fez.57 Well-Known Member
    Putting yourself on a diet is the most cost effective method of saving weight lol. It is correct that saving in unsprung weight will much much more effective than sprung weight but apart from wheels there is not huge weight savings to be made a titanium exhaust system will knock off a few kilos and a lightweight battery is also good.
  3. Andrewzzz
    Andrewzzz Active Member
    I'm on the diet myself, it is not cheap!! Not eating or eating little is not a diet, its starvation. ;-) I eat 1kg of meat and veg every day and it is not as cheap as eating "normal" food. :D
  4. JM1
    JM1 Active Member
    954 has a titanium exhaust as standard I think (definitely the can, possibly not the rest of the system though, can't remember).
  5. kpone
    I thought the rest of it was Titanium too, but I can't be certain. It may not have been the 954. I am sure one of them around this age did though.
  6. Juggler87
    Mine came with a stainless steel "fuel" end can. Almost certain it isn't OEM. Asthetically it doesn't do it for me. The bike has never been dropped though judging from the condition and millage. Cannot see anyone swapping stock titanium for SS. Will check the downpipes. :) Thank you for the feedback guys.
  7. sps170373
    The base weight of the 954 is about 166kg so it was light to start, but with a titanium exhaust and bolts, carbon wheels you could easily lose 7 kg
  8. JM1
    JM1 Active Member
    http://www.hoc.org.uk/gallery/press/2002/2002_CBR900RR_Fireblade.pdf
    "New Titanium Exhaust
    The FireBlade’s remarkably lightweight, high-performance titanium
    exhaust system remains essentially the same as the current model, with the
    same H-TEV (Honda Titanium Exhaust Valve) working as part of the H-VIX
    (Honda Variable Intake/Exhaust Control System) to maintain the ’Blade’s
    sharp performance throughout the rev range. The latest addition to this system
    is an ultra-lightweight new titanium silencer with a brownish grey finish and
    milled aluminium end caps that emphasise its high performance with finely
    executed good looks. In its G-type configuration, the exhaust system also
    contains an inline catalyser element to minimise emissions of environmentharming
    exhaust gases."
  9. Blackness
    Blackness Active Member
    If your changing the chain and sprockets you could look at putting a 520 kit on it, and also depending on if you wanted to play with the gearing for more acceleration etc !
  10. Blackness
    It also looks like you could loose a good 1/2 kilo in hair mate ;)
