I didn't find much information when I searched so I thought I'd post some. I wanted a QA throttle for my 2007 cbr1000rr but didn't want to spend a load or muck about with glueing bits of plastic to the throttle. I bought an hrc throttle tube on ebay with the part number 53141-MT7-000 for about £20 and fitted it with the standard cables. You will need to lift the tank and remove the airbox in order to give yourself enough slack in the cable to fit this but the standard cables should be fine. Cheers, Mark
