Question re Oil
Discussion in 'Maintenance' started by bradt, Apr 21, 2023.
  1. bradt
    bradt Elite Member
    Sorting out my garage and came across 2 x 4ltr containers of the oil used on my bike both had been used for previous oil changes on the bike (same make and viscosity) 3ltr used in each change leaving a 1ltr in the container the date stamp on each container is May 19 and November 21 ( oil change last year was done at bike workshop) question can these oils be used still/ combined or should I take them to the local tip and buy new oil for this year's change ?
  2. Coda
    Coda Active Member
    Oil doesn’t “go off” like fuel does as far as I know. I’d use it.
    • Agree Agree x 5
  3. Boothman
    Boothman Elite Member
    It’ll be fine - buy another 4 litre bottle of the same stuff and use 1 litre of that with the remnants of the previous.
  4. bonjo
    bonjo Active Member
    if by used, you mean left over then it is pretty safe to use if it is kept is a sealed airtight container
  5. PauloHRC
    PauloHRC God Like
    It'll be fine that Brad ;)
