Question regarding 2012 blade clocks function
Discussion in 'General 1000RR Discussion' started by lambchops, Dec 5, 2013.
  1. lambchops
    lambchops Elite Member
    On the 2012 and onwards blade are the controls on the handle bars used for anything to adjust the clocks or is it all controlled from the two buttons on the clocks?
    Need to know for my little project :)
    #1 lambchops, Dec 5, 2013
  2. Jamiestrada
    Starter button is used for lap timer otherwise it's the two on the dash as far as I know
    I haven't played with it much yet need to set shift lights etc
  3. lambchops
    OK thanks Jamie, this is what I was thinking, perhaps the starter is used as an enter button or something when running through the menus.. If its just the lap timer then fine I can live without it. Seems to be a lap relay unit also looking at the wiring diagram so dont think it will be easy to carry over to the RR4
  4. Jamiestrada
    No problem just checked handbook and it's only used for that all other functions are set by two clock buttons
  5. martinowen
    Once you have practiced on your blade lambchops how much will it cost to fit one too mine :D
  6. lambchops
    Ah great news thanks Jamie.
    Will keep you posted martin, maybe able to help you out :)
  7. sinewave
    Yep, all settings are done on the clock buttons, the starter is just for starting off the lap timer etc
  8. lambchops
    perfect thanks guys :)
