quick clutch question on the RR8 onwards model
Discussion in 'General 1000RR Discussion' started by phantom, Oct 8, 2012.
  1. phantom
    phantom Active Member
    just wondering if any of you guys notice a slight "creak" so to say
    in the clutch lever when you go to shift down?
    feels a bit like a cable on the way out but only does this when
    you are riding.stationary it doesnt happen.
    anyone else have this??
  2. thefirebloke
    thefirebloke Elite Member
    Just about everybody I've talked to. It seems it's quite normal.
  3. phantom
    ah I was thinking it was maybe something to do with the
    clutch setup on the blade.thats put my mind to rest.
    thanks
  4. Carl
    Carl Well-Known Member
    Having just bought a new blade with a slipper clutch I experienced the same think, I took it back to the honda garage to be informed that it is normal for a slipper.
  5. billo01
    billo01 Member
    Yeh same on my 09. In addition to this though, at the clutch end, I did notice on mine that the clutch cable guide was set at a slightly different angle to that of the run of the cable, this caused the cable to "rub" on the inside edge of the guide when the clutch was in or out. No big deal I guess but with the guide being in parallel with the cable this would help towards a slightly smoother operation.
  6. Only1Matrixxx
    Only1Matrixxx Active Member
    WOW, I have the same thing with mine... The clutch cable has actually worn down the guide because the angle was wrong...
  7. Only1Matrixxx
    Duplicate post...
    #7 Only1Matrixxx, Oct 9, 2012
  8. phantom
    I must check mine for wear too.
    you think with a few of us asking the dealers or other owners then
    they might put a note in the owners book that nothing it wrong.
