Just trying to undo the O2 sensor on the exhaut it won't move have tried heating it up out WD40 on it still won't move can I just cut the wires least them I can get a ring spanner on it or just leave it there with the wires cut would this be ok
iv just left mine where it is , you might want to return it to stock if ye ever sell the blade and remove the pcv
i would just follow the wire back and unplug it from the loom. i wouldn,t just cut the wires and leave them. once unplugged get a ring spanner just down over the cable and a couple of taps on the spanner with a mallet might shock it loose.
So you just mean leave the sensor in the exhaust diconnect the wire at the other end then connect a O2 elimator is this ok
Thanks you guys don't know what I'd do without you can't way to ride it now to see if this had cured my throttle response issue
