Quick shifter sensors
Discussion in 'Mods, Upgrades, Accessories and Products' started by steve750, Feb 23, 2016.
  1. steve750
    steve750 Active Member
    Hi chaps,
    I'm wondering if a bazzaz sensor can be replaced with any other sensor. I know it's a 3 pin lead whereas others are 2 pin. I've looked at an alternative sensor but it will cost around £50 and I'm not brilliant with fiddling tasks if I'm honest.
  2. brg1000
    brg1000 Active Member
    The bazzaz has three wires as it requires 9-12 v on one wire to operate the proximity sensor. The other two wires provide the trigger and the earth. I know some people have replaced a Bazzaz with the likes of a dynojet sensor and it apparently worked fine. I can repair Bazzaz shifters if you are interested or I buy broken ones.
  3. steve750
    Thanks for your reply brg. Would a dynojet sensor not need the 12v feed?
