Quickshifter false neutrals
Discussion in 'Mods, Upgrades, Accessories and Products' started by hoggyjay, Aug 14, 2015.
  1. hoggyjay
    hoggyjay Active Member
    Hi,
    Running a Bazzaz QS with a replacement pressure transducer after the original failed. As per the title I am hitting false neutrals between 3-4 and 4-5 gears.
    Would a simple solution be to increase the gear/engine cut time allowing the next 4th or 5th to be selected before the power is replied?
    Any help would be appreciated?
  2. dansp1
    dansp1 Active Member
    What cut time are you using?
  3. RepsolRuss
    RepsolRuss Active Member
    Adjust the cut time. I'm running the latest Bazzaz shifter with a 50/55ms cut time from 3-4-5-6. Be positive with your shift too.
  4. hoggyjay
    I'm offshore so can't say what cut time I am using at the moment. The shifter was set up during a dyno run (with original sensor fitted). I'll check the timing when I can and adjust to 50/55. I'm normally very assertive with the gear lever, especially after hitting neutral on the Hislop curve at Knockhill!!!!!
  5. dansp1
    I haven't used a bazzaz, but i wouldn't go lower than 50ms, probably that is too short a kill time
