Quickshifter - how often do you use it?
Discussion in 'Mods, Upgrades, Accessories and Products' started by jokeshopbeard, Jun 24, 2013.
  1. jokeshopbeard
    jokeshopbeard Active Member
    Just wondering, for those that have one fitted, how often you use it? For every gear change? 50%? 75% of the time?
    Obviously all upshifts are not done at full throttle, so do you use it at half throttle?
  2. RichC
    RichC Active Member
    I use mine for every shift just so easy and when making progress.
  3. martinowen
    A friend of mine just had one fitted to his GSXR by Arthur on here, he loves it and recommends to anyone
  4. fez.57
    fez.57 Well-Known Member
    Dont use it in a town or a city but use it all the time on the open roads. exept 1st -2nd
  5. scooby
    scooby Elite Member
    you can set them to only come in at a certain rev limit,mine are usually around 6/7k,plus never use it from 1st-2nd,bit too harsh on the g/box.
  6. vvtr
    vvtr New Member
    we was roffling at a chap we know the other day - he's got one on his...
    sets ofF and is in 6th within 5 seconds de der der dur durrrr Duuuurrrrr... then pootles along at 5 under the limit, never overtaking, never filtering, always preaching IAM.
    what is the point lol :rolleyes:
  7. Alblade
    Alblade God Like
    Like others on here, don't use it 1st to 2nd, but other than that most changes - miss it when I ride a non-QS bike.
    Best thing is when you sell bike you remove it and fit it to the next unlike cans etc.
  8. phantom
    phantom Active Member
    so for the road it truly is pointless because if your using in from
    2nd onwards say at 6k rpm you are already doing 88mph.
  9. Remal
    As posted I won't use it in towns or 1st to 2nd very often but other than that I use it
  10. Pete1987
    Pete1987 Active Member
    i use mine all the time, although mines set to be active from 2500rpm, so i use it when pootling about or when i'm on a longer run too.
  11. Herman Toothrot
    Herman Toothrot New Member
    What exactly do they do? Descriptions above make it sound more like an auto?
  12. martinowen
    In some ways they are, they cut the ignition when you change gear meaning no clutch required, giving quicker gear changes and you don't need to let of the throttle
  13. phantom
    I used to like listening to the road race bikes doing the pop's
    when shifting, that would be one of the reasons I would have
    wanted one lol
  14. lexwon
    lexwon Active Member
    I love when mine does it :)
  15. phantom
    do new blades do that still ?
  16. lexwon
    yeah they do :)
  17. phantom
    hmm maybe look for one then lol
  18. scooby
    scooby Elite Member
    it's essentially changing gear (up the box,not down) without any physical throttle closing,so when pressure is applied to the gear shifter,a sensor cuts the spark or fuel(depending on type) unloading the gear box and allowing the gear change.the idea is to be able to keep the throttle fully open longer during gear change so saving valuable tenths of a second per lap.you can do a very similar thing manually though.
    when your changing gear,load the gear selecter as if your about to change gear and roll of the throttle very slightly,you'll find it'll pop into gear as the g/box unloads slightly without having to fully roll off.
    q/s are very good bits of kit on track,and i do miss mine when i dont have it,but for the road,like a lot of things they are pointless,and can be very expensive if not set up right.(as with trackbikes aswell)
  19. Jamiestrada
    I use mine everyday on my commute, I am so used to it now I miss it when its gone so always fit one, its not a must have but then nor is a can or levers or half the stuff we pile on the bikes. On the blade i used it from 2nd gear onwards and the HM plus never missed a change
  20. BlackDevil
    BlackDevil God Like
    I am using mine ( HM SH Plus ) as much as I can, even on the road.
    Its fun to ride and I never go back to "normal shifting" again.
    Also I tried out the Quickshifter on the BMW S1000RR and BMW K1300S,
    they are different on both bikes, especially on the K1300S.
