Little trick I came up with when trying to reconnect the coil plugs when removing a quickshifter. This should also work when installing a quickshifter as the plugs are same dimensions. You need to get your fingers or suitable tool to press the release tab on the plug then the rest is simple. I was able to do the job using nothing more than a pair of chopsticks,yes chopsticks,and a cable tie. Using the chopsticks to push off the coil plug and retrieve it from the area your fingers don't reach,then use the cable tie as shown on the plug you're trying to connect after joining the quickshifter loom,position it over the end of the coil and pull. Plug connected. Retrieve cable tie and move onto next plug. I was able to remove a quickshifter loom and reconnect the original plugs without having to remove side panels and air ducts.
