Wanted to get some crash bungs for my 2013 Blade, always go for R+G but don't understand- on their site Aero style bungs = 52.91 ex VAT, while Aero style bungs (NON DRILL ??) = 208.33 ex VAT, Just a slight difference!! Does this mean if I go for the cheaper version I have to drill through the fairing? thanks
Great info big thanks, fantastic video dave d, now understand what I need to do, pretty easy will go for the R+G drill types and save a packet! cheers
I've recently drilled my 2011/12 blade, the kit comes with a spiked bolt you loosen off the fairing, do not remove, and replace the engine bolt with the spike, as you push the fairing back the spike makes a dimple on the outside of the fairing, drill a pilot then a 28mm hole with the fairing in place, bobs your uncle! It is very very simple on the newer bikes.
Use a Cone cutter rather than a Hole Saw, it gives a nicer finish! 3pc HSS STEP DRILL SET4-32mm HOLE SAW CONE CUTTER LARGE STEP DRILL SET TITANIUM on eBay!
