r&g boot guards
Discussion in 'General 1000RR Discussion' started by keithg1748, Nov 13, 2016.
  1. keithg1748
    keithg1748 Active Member
    evening all , I just wondered if anybody has fitted any of these and are they easy to fit etc ? and what do they look like , thanks.
  2. poppy72
    poppy72 Active Member
    Yes I've fitted them easy to fit worth the money
    Sent from my GT-I9505 using Tapatalk
  3. keithg1748
    thanks do you have any pics of yours ? , and do you use heat to put them on or is it just peel and stick
  4. poppy72
    I used a hairdryer warm them up a bit they look ok I'm trying to put a picture up now
  5. keithg1748
    cheers mate.
  6. Nickw
    Nickw Active Member
    Interesting thread, and coincidental...... I was just about to order a set of these....
  7. tony lomas
    tony lomas Member
    I've fitted them a while ago used a hair dryer to heat up to look good just take your time when fitting
  8. poppy72
  9. jgraham562
    jgraham562 Active Member
    I bought a sheet of black vinyl like you use for wrapping bodywork and cut the shape out to give me a boot guard. Simply heated and applied. Cost me a quid for an A4 piece of vinyl which will make many guards. Looks almost invisible on black swingarm and has been wearing remarkably well too.
  10. poppy72
    • Thanks Thanks x 2
  11. RazorBlade
    RazorBlade Member
    What sort of heel guard is that on the swing arm mate? Both my heels are rubbing on the swing arm and need something that looks a bit better than the gaffa tape I've got on there now.
  12. poppy72
    It's a carbon bit there was about 20 of us bought them from of this forum
  13. RazorBlade
    RazorBlade Member
    Thanks mate. Looks like I might just have to bite the bullet and buy the R&G kit.
  14. Nickw
    Nickw Active Member
    Snap.....
