R&G Engine Covers
Discussion in 'Mods, Upgrades, Accessories and Products' started by Greco, Jul 28, 2015.
  1. Greco
    Greco Active Member
    Did any of you guys use or used these on your bikes? I am trying to find something suitable for my 2007 blade and so far these stand out and the carbon covers from Conquest Carbon. Any thoughts please.
    Thanks you
    Greco
  2. t0m541
    t0m541 Senior Member
    I have R&G ones on my '07, look ok and are well made.
    If you do fit them, make sure you put thread seal or similar on the new longer bolts they supply, otherwise oil wicks down the threads and you suddenly find you have a mystery oil leak.
    It took me a while to twig where the oil was coming from on my right boot, everytime I went out for a ride.
    It's only the clutch cover side that leaks as the other side houses the generator which doesn't have any oil in.
  3. Greco
    Greco Active Member
    Cheers mate
    I will do. I already placed an order for an r&g set. Price was ok cause the carbon was way too much, over £200 for something cosmetic. Maybe later on..
  4. raphael
    raphael Elite Member
    funny you should say that fella! i have a 12 plate with the cover on the left side and after giving it the beans i get a small leak on one of the pipes under it.
  5. Barstewardsquad
    Got them on my RR7 and have tested them in anger last year :(
  6. Greco
    Greco Active Member
    Fingers crossed i'll be ok. I'll check every bolt and seal everything to avoid any oil leak.
