R&G Protection - Engine covers and Frame Sliders
Discussion in 'Mods, Upgrades, Accessories and Products' started by KPH, Jun 15, 2015.
  1. KPH
    KPH Active Member
    Just finished installing some R&G parts - left and right side engine case covers and frame sliders. All went together very easily and fitted well.
    One question - the R&G literature states a torque of 40 Nm for the frame sliders, but the Honda Manual states 64 Nm. Has anyone come across this before and what would you recommend ?
    One thing I did noticed was that when tightening the sliders, they would rotate out of position - I ended up having guestimate how much it would rotate and wind it back, so when tightened it would end up in the right position.
    Before and after photos below:
    Left hand side - handy that the fairing split was where it was - meaning that the lower fairing can be easily dropped down and removed ( the R&G slider stays in place)
    CBR - LHS Engine Casing 01.jpg CBR - LHS Engine Casing 02.jpg CBR - LHS Engine Casing 03.jpg
    Right hand side
    CBR - RHS Engine Casing 01.jpg CBR - RHS Engine Casing 02.jpg CBR - RHS Engine Casing 03.jpg
  2. Muffking
    Good work.
    Re the slider bolts, R&G use a milder metal which can bend in an off. It may be that over tightening the bolt can weaken it.
