Been looking at these on R&G site and wanted to ask which is the best option or any other options for that matter. I've an ABS Blade and only have the option of fitting these on the right side as the left side has all the plastic work on. Slider or Case cover?? Cheers all
I was pondering the same thing and thought Case over slider incase a bolt sheared off the Slider on a off and it being a nightmare to remove.
Slider for me. After my off on Jan 1st the slider took all the damage. Cases were untouched and the fairings were almost unscathed. Just replaced it today and it uses a long 19mm bolt which replaces one of the engine bolts (I think). Slider was mullered, but the bolt inside was still perfect. Unbolted, binned, bolted the new one on. 2minute job Here's a video of the damage and you can see how well the slider did
Mine's an abs bike and I've bought the gb racing engine covers and apparently the covers fit both side according to the mechanic. Not seen the bike since he fitted them though.
