R77 full system and map advice needed
Discussion in 'Mods, Upgrades, Accessories and Products' started by Simon Parrish, Apr 26, 2014.
  1. Simon Parrish
    Simon Parrish Active Member
    Hello
    Got a 2012 blade and have fitted an R77 system with carbon end can, PC5 and Autotune and a K&N filter.
    Does anyone know where I can get a custom map for it? Nothing on dynojet website.
    Has anyone heard of any problems running this set up? My mechanic says it needs a dyno set up.
    I live in Leeds so any advice or experience of this set up would be appreciated.
    Cheers
    Simon
  2. Slick
    Slick Elite Member
    Welcome to Power Commander Motorcycle Fuel Injection Tuning Module
    nothing beats a custom map, even for the same setup the maps are different for each bike.
    Not on a CBR but had a similar setup on a CB1Kr, you need to keep an eye on what the AT is doing and so don't blindly accept the trims. You will find it struggles in some areas especial low TP%/revs. Takes a bit of learning but once you understand the what the AT is doing it's an awesome tool. I will be fitting the AT to the CBR though when a get a bit of time
  3. iang27
    iang27 Active Member
    There is a guy in York area who is meant to be quite good.
    Someone with a similar system may send you a map to try, Navvy had one I think ?
