R77 melting lower fairing.
Discussion in 'General 1000RR Discussion' started by Shing90, Apr 13, 2013.
  1. Shing90
    Shing90 Active Member
    I have noticed that my new R77 exhaust has slightly melted the lower body/exhaust fairing onto the S bend of the exhaust. Not a big problem but I think I will just take the lower fairing off and dremel a section out of it.. Have any of you fellow Yoshi-ites experienced this and if so what did you do to remedy it?
  2. hump333
    hump333 Member
    You need some silver heat proof padding or exhaust rap
  3. Shing90
    I plan to get some silver heat tape mate and put on the inside of fairing, but I think a section will still need to be cut out as its touching.
  4. hump333
    hump333 Member
    Maybe u need to twist the s bend around a little from the fairing :)
  5. Shing90
    Hmmm.. Could be worth trying.
  6. Pete1987
    Pete1987 Active Member
    I used a longer bolt on the pannel and spaced it out with a spacer/washers. doesnt touch on mine.
    Might help you before you start dremelling out pieces
  7. Shing90
    Now that sounds like a good idea.. I'm just a typical bloke, first thoughts were straight for the power tools. :D
  8. ninja
    ninja Active Member
    #8 ninja, Apr 13, 2013
  9. Shing90
    Interesting.. Something to look out for.
