Race fairing etc
Discussion in 'General 1000RR Discussion' started by Guy Hemmings, Mar 2, 2020.
  1. Guy Hemmings
    Guy Hemmings New Member
    Has anyone tracked or put a 2008 into race plastics as I wanted to know what they did with the air sensors/ diaphragm etc that runs on top of the air intake to the air box.
    Is it needed ??
    Thanks
  2. TheMickster
    TheMickster Active Member
    Hi
    It was already done on mine, but I think most will remove it completely (diaphragms/solenoids etc) and if you keep the original air tubes just seal up the holes.
    Cheers
    Mike
  3. garybee
    garybee Member
    I've just put a race fairing on mine ('09). I plugged the vacuum line from the engine and removed everything else. Started it up and I don't have any warning lights. I have a pair of race air tubes an the way. There's a place just down the road from me that has a rolling road. I'll probably take it down there for a run to make sure it isn't lean anywhere.
  4. Guy Hemmings
    Thanks for the reply, much appreciated and I'll do that.
  5. Guy Hemmings
  6. Guy Hemmings
    Brilliant, that's a good result, I'll do the same.
    I'm in Uttoxeter so will probably take mine to PCR performance at Cannock, I've heard a lot of good feedback.
    Where you taking yours.
    Thanks.
  7. Guy Hemmings
    Cheers for that, I'll give it a go also.
    PCR at Cannock have had rave reviews.
  8. garybee
    garybee Member
    I live a few minutes from 'Black and White Bikes' in Lincolnshire. I've bought a few things from them and they seem fine but haven't had cause to use them for anything that requires trust yet. I'm a bit wary of letting anyone else do vehicle work. A rolling road session could be seen as an opportunity to tell me my bike's dangerously lean, requiring me to have an ECU mapping session at a cost of ££££
  9. Barstewardsquad
    They used to come on here, not sure if they still do. Always seemed nice enough and I keep meaning to pop in when going to the outlaws, just never seem to go via that route during opening hours.
  10. Noel
    Noel Active Member
    Black and white bikes have a column in fast bikes
  11. Guy Hemmings
    What did you do with the plugs that go to the air scoop valves, did you need to link them out or just leave them.
    Cheers
