Race shift conversion
Discussion in 'Mods, Upgrades, Accessories and Products' started by flatstickHRC, Jul 6, 2011.
  1. flatstickHRC
    flatstickHRC Active Member
    I want to run reverse shift on my bike.
    SES do a different foot lever which allows for this and mounts higher up for more ground clearance
    Only thing is I've had a rough measure and in the opposite position the rod will clash with the front sprocket cover so it will require notching or removing. I have had this on my race bikes and it's not an issue but want to keep the cover on this bike as it's a road bike
    Has anyone used this set up and had similar issues or know of a different hear lever I could try? Promach is £160 and requires the removal of the sprocket cover too.
  2. Nutty Tart
    Nutty Tart Well-Known Member
    Dunno if its any help but the Gilles rearsets give you the option of road or race shift and it doesn't foul the cover
  3. fisher
    fisher Active Member
    Is there enough room to add a spacer on the spline knuckle? just a thought
  4. flatstickHRC
    yeah the is but ive sorted it now
    just going to notch the plastic cover and get a replacement when im finished. theyre only about £10 new
  5. stylo
    stylo Active Member
    Can you guys post pics of your different reverse shift conversions. I need to change from the standard and I need some references if I get in a jam.
    thanks
  6. phantomx0_1
    phantomx0_1 Active Member
    My R&G sets give you both options and its simple to do. Plus the look cool!
  7. scooby
    scooby Elite Member
    promach rearsets just have holes either side of the bottom pivot point.you attatch your shift rod to either side depending on your preference.easy.:)
  8. stylo
    stylo Active Member
    Sooo.. got myself a set of Arata rearsets and as scooby says the only bit needed for a reverse shift conversion is in the pic below.
    Rod to the left of the pivot nut gives reverse shift. To the right give you the standard pattern.
    The DIY guys amongst us can make their own ;)
    #8 stylo, Sep 17, 2012
  9. loganlexow
    loganlexow Member
    HOLY BALLS OF BRILLIANCE!!!!! I'm not worthy of this here forum!
