Race tank cover 09/11
Discussion in 'Mods, Upgrades, Accessories and Products' started by rosier1uk, Jul 13, 2015.
  1. rosier1uk
    rosier1uk Active Member
    Thinking of getting a race tank cover for the blade understand it might take a bit of fetling to fit but my biggest worry is how do these seal around the fuel cap on a standard tank worried if a big gap water may get in and bollocks the electrics especially when washing the bike and are they strong enough when fitted over standard fuel tank sure there's a few people have these fitted on road bikes can help me
    Many thanks
    Brian
  2. Moon
    Moon Active Member
    I have a BSB one designed for HRC subframe on standard bike.
    I had to drill the holes out a little where it bolts to subframe to make it fit and it fits around the fuel cap fine although i have to use a little bit of grease on the rubber sealing ring to squeeze it on
  3. rosier1uk
    Cheers moon
  4. Moon
    Moon Active Member
    I think it's the same shape apart from the bit you crack yer nuts on is higher to allow for a larger tank? Obviously mine is just empty space underneath as I have standard tank.
    It's solid and does not move about when hanging off with your knee etc
  5. rosier1uk
    Thanks again moon looks sweet
