Racefit Growler Black Edition PCV Map Available soon
Discussion in 'Mods, Upgrades, Accessories and Products' started by Emywmpb, Mar 13, 2015.
  1. Emywmpb
    Emywmpb Active Member
    I have read a few threads in which guys have fitted a Racefit Growler Black Edition exhaust and a PCV to their bikes and not been able to find a suitable map to download from the Dynojet database.
    Two weeks ago I took my 2012 Blade to Dynojet HQ in Preston and in exchange for a free custom map, they added the result to their database. I found that, even though Racefit said I wouldn't need to correct the injectors, I had lost some power below 4000rpm and the bike spent far too long hunting in idle.
    The only mod ive fitted which would have changed the A/F ratio was the exhaust (no aftermarket air filter etc), so for anybody out there using a 'not quite perfect' downloaded map, my Racefit Growler specific one should be available very soon.
    The PCV/map has totally sorted out the power loss at low revs, and added 9bhp to peak power. It's never easy to improve the linearity of the power curve significantly on our bike, but the fuelling was all over the place before the map and is now perfect.
    To all those that this may help, enjoy!
    Martin
    • Like Like x 7
  2. scooboo81
    scooboo81 Member
    I have a map for a racefit growler black edition with P.C.5 on my home computer.
    Its a fantastic map, great A/F ratio and a nice smooth power curve, I can send anyone who requires it in a few days or so once I'm home from working away, otherwise Im sure forum member Jim Green has this too
  3. Chriscbr
    Chriscbr Active Member
    I have a racefit growler on 2014 model .its much smoother with this exhaust vs the original on the standard no remapped ecu but i was considering fitting a power commander to reduce the snatch at low revs. Any views ?
  4. TheRamJam
    TheRamJam Well-Known Member
    Hi can you send me the map please as i will soon have bought a Race fit :)
    Thanks
  5. sps170373
    I've got a map I can send
  6. scooboo81
    scooboo81 Member
    I will do mate, will be towards the the end of the week, still working away at present.
  7. bandit_287
    bandit_287 Active Member
    Hi Couldyou please send the map to me too? I'm trying to find the Racefit Growler map on www.powercommander.com and can't find it. I'm trying to map my friends 2010 with this fitted.
    Many thanks.
  8. scooboo81
    scooboo81 Member
    Here you go bud,
  9. scooboo81
    scooboo81 Member
    What's your email address mate?
  10. bandit_287
    Thanks again mate, map has been installed successfully.
  11. scooboo81
    scooboo81 Member
    Good stuff
  12. TheRamJam
    Map received mate. Some man thanks.
  13. scooboo81
    scooboo81 Member
    No worries
  14. Ross9632
    Ross9632 New Member
    i have black edition fitted, currently using an old map. id quite like this one if you could help please? [email protected]
  15. Ross9632
    Ross9632 New Member
    map received, many thanks mate
  16. JimGreen
    JimGreen Active Member
    Yep, I had a Racefit Growler Black Edition on my 2011 Fireblade, it was live mapped onto my PC5 at Crescent Motorcycles and the mapping was done by their World Superbike Technician. On my 2011 blade I was very happy with the results. Quite willing to send to anyone who want's it. I did send the map to PC but it appears they haven't added it to their library.
    As far as I'm aware, this is good for the 08 - 11 bikes (Prior to digital dash) running a PC5
    Here's my dyno printouts showing a 5 bhp increase in outright power and + 4 lbs torque. When I spoke to their tech prior to him mapping the bike, I told him I didn't want it mapping for track use, but wanted it for road/fast road.
    Runfile (Red) shows the power/torque results after mapping.
    Runfile (Blue) shows the power/torque prior to being mapped.
    You will see that there was a power and torque increase throughout the whole rpm range.
    On the second print out below you can see how consistent the AFR remains throughout the whole rpm range........
    I was totally happy with the way the bike rode following the remap and the hunting at tickover was eliminated.
    Quite happy to send the map if anyone wants to use it.
    Only other changes to the bike was a K&N Air Filter and O2 eliminator fitted. The bike was on the dyno for almost two hours.
    Once my 2015 bike is run in, it will be fitted with the same set up, unfortunately the Racefit Growler Black Edition I had on my 2011 bike won't fit onto my 2015 as the catalytic converter has been repositioned on the later bikes......... arghhh..
    #16 JimGreen, Mar 24, 2015
  17. Ross9632
    Ross9632 New Member
    Hi mate, i wouldnt mind giving this map a go too if you could email it too me? be happy to offer my feedback. [email protected]
  18. JimGreen
    You have email Ross................ Regards Jim
  19. maluczczi
    maluczczi Active Member
  20. stu2907
    stu2907 Active Member
    This may sound a dumb ass question but which power commander do I need to fit my 2013 HRC? Just been on website and loads of models etc..
