Hi Guys, I've just removed my Black Edition as I'm on the look out for a Carbon Akrapovic/Yoshi R77 pipe instead I'd prefer a swap, as I'd spend the money on other things if I couldn't find a replacement in good time It's covered less than 1000 miles. I've just MOT'd the bike which has only done 500miles since the last one. In excellent condition, no nicks marks or scratches I still have the original box, but its been water damaged from storage Comes with the infill panel and all bolts and washers Located 10 miles out of Cardiff, but do travel around the UK a lot Thanks Mark 07917 Double three two Double three one effortless_power AT Hotmail DOT com I'll get pictures up tomorrow for you guys
Im not far from Cardiff ...Blackwood have nothing to swap but what you looking for to sell mate? also does it have a DB killer? as I heard they are quite loud??
Gshock: Im actually in Llantrisant, so just down the A470. It doesn't have the Db killer end cap, and they are loud. Gives an epic crackle on overrun, which is addictive. Would be looking for £375 for it, it's over £500 new, and only covered a thousand miles max
Looks nice any probs with mot with it fitted buddy? also mate (sorry) is it plug and play? no need for mucking about with fuelling or power commander?
I just take it off for the MOT, a 10 min job to swap. I haven't got any other engine mods, no power commander or map. It sometimes hunts on idle, nothing dramatic. It doesn't have any adverse effects when driving though
It should be fine for the mot as is they should just put loud exhaust on the certificate, if you find you want a bit less noise at times racefit sell growler end caps and you can then fit one of their baffles/ noise reduction inserts I have a black edition with growler end cap
No issues, did hunt a little on warm up before I put an O2 eliminator on, now got power commander and no problem
Are these too loud for track days? Even with baffle in? I have an r-77 at the moment but like the look of these
I've never taken my bike on a track but they are very loud. You can get Racefit to fit the original Growler end piece to the can so you could run a baffle, (like the one above^^) that way it could pass track regs
Even with a baffle it's got no chance of passing any trackday noise test !! 111dbs without 107 with, that was at oulton park. Think donnington is the loudest @ 105
This may sound very amateur.... I fitted my black addition recently and want to get the PCV fitted and dyno'd to get the best performance I could. When you say you fitted an O2 eliminator, where/what are you actually putting/connecting it/to? I have already fitted the original sensor to the pre-fabricated hole on the pipe. Down on the left hand side of the bike where you release the clamp.
An o2 eliminator replaces the lambda sensor, just follow the lead back from it and unplug and plug in the o2 eliminator, you'll need a sensor bung too to O2 eliminator are about £15 and sensor bung about a £5 both from ebay
