Racefit infill
Discussion in 'General 1000RR Discussion' started by tuktuk, Apr 2, 2018.
  1. tuktuk
    tuktuk Elite Member
  2. PauloHRC
    PauloHRC God Like
    Mines for 2009 but if the mounting brackets are the same they do take a bit of working out. The brackets are peculiar angles and you'll need to try out a few combinations before it hits you in the face.....that's what I found anyway!
  3. tuktuk
    tuktuk Elite Member
    The plan is to try and fit something around this exhaust ive put on. Looking at pics id have to trim the racefit part down a fair bit so worried id be removing areas where mounting is needed if you get what I mean.
  4. PauloHRC
    PauloHRC God Like
    I see your predicament......on mine the fixing/mounting points are situated more toward the front of the carbon infill panel. Leaving quite a large area at the back where the exhaust exits. I suppose if I was in your predicament then yes I would be able to trim some away without going near the mounting points.
    Trouble is on the '12 onwards one in the link you posted you can't see the where the bolts are like you can on mine!
    I've posted a pic......maybe give the guy at racefit a call, they're very helpful I've found.
  5. Dave dunlop
    Dave dunlop Elite Member
  6. Dave dunlop
    That's about as close as I can get in without removing panel... hope it helps fella:D
  7. PauloHRC
    PauloHRC God Like
    You trimmed that yourself Dave.....and what exhaust is that??
    #7 PauloHRC, Apr 3, 2018
  8. tuktuk
    tuktuk Elite Member
    Cheers guys, much appreciated.
    Dave, looks like it only mounts along bottom? Ideal if that's the case. Did you trim yours and if so how easy was it? And finally, are you selling those wheels yet? :D
  9. tuktuk
    tuktuk Elite Member
  10. Dave dunlop
    Yes Paul, Trimmed to fit the Akropovic.. was running the Austin Racing before.
  11. Dave dunlop
    IMG_2744.JPG IMG_2857.JPG Now running this....
  12. Dave dunlop
    Yeh mounts to panel across the bottom so you should be ok... only trimmed to fit Akro as the link pipe was shorter than the Austin Racing item and it didn't clear the panel. I've also made a small flat bracket that attaches the Racefit panel to the OE fairing but at the very bottom so it's not in the picture... really needs the 3rd fixing underneath or the panel can vibrate with just the two fixings with the Racefit unit....
    Wheels are staying for a while longer I'm afraid....:D:D:D
    The panel trims up quite well and is easy to work with.... So you shouldn't have any issues modifying to suit.
  13. Dave dunlop
  14. nigelrb
    Bleedin' heck. Why is it that other people's bikes always look better than our own?:confused:
    A real credit to you Dave. Have just incentivised me to re-appraise my own skills or lack thereof.:(
    By the way, are they 'forged' wheels? (I'm not after them - just interested)
  15. tuktuk
    tuktuk Elite Member
    Cheers Dave, sounds like the way forward.
  16. Dave dunlop
    Cheers Nigel... they are 'Forged'
    Full spec on Dymag website...
