radial clutch master cylinder
Discussion in 'Maintenance' started by huw williams, Mar 16, 2018.
  1. huw williams
    huw williams New Member
    has anyone put a radial clutch master cylinder on a 005 1000rr nissin do one with a 19mm piston , has anyone fitted one thx
    #1 huw williams, Mar 16, 2018
  2. BikersDiscountStore
    Do you need a 19mm piston? Accossato make a 19 x 20 clutch cylinder but it's usually fitted to ZZR1400, V Max & the like. A 16 x 16 or 16 x 18 would probably do the job better.
