Hi gents I'm moving my overflow bottle to the front ie HRC ones. Can someone recommend where to get the breather hoses and over flow hoses from? What size do I need? Thanks.
Surely you have to match the hose to the fittings? I'd go to B & Q. They have a range of sizes. I've purchased there before for brake bleeding tube.
That's correct this is a fire blade forum so was hoping someone would know the size so I can pruchase off the internet. But I will try b&q thanks Nigel
The clear pipe I used is 6mm Internal and 9mm external diameter 3m in length will be more than enough you need. Try eBay. Taken from another post
