Rear Brake Bleed...
Discussion in 'Maintenance' started by Mr OCD, Mar 5, 2015.
  1. Mr OCD
    Mr OCD Well-Known Member
    Any tips for doing this?
    Changed the rear hose, bled it the and pedal still feels pretty soft... certainly not like it was before I fucked with it! :D
  2. Barstewardsquad
    American so a bit annoying at times, but it covers the bases.
  3. Mr OCD
    Cheers for that... pretty much what I have done so will have another go tonight.
    I don't remember seeing the white pad in the reservoir though... ;) oops...
  4. TheRamJam
    TheRamJam Well-Known Member
    Don't think the white pad will have that much of an effect on the stiffness of the pedal.
    I use a syringe to bleed brakes. Its pretty easy, virtually no mess and works really well.
    All you do is fill the syringe with brake fluid and attach to the caliper bleed screw with some clear tubing. Crack the bleed screw open and slowly pump the fluid back through the MC into the reservoir. Bingo job done!
  5. Mr OCD
    It's more the fact I didn't even see the white pad ... lol
    I actually reverse syringed the caliper... i.e. sucked the fluid through from res. to caliper.
    My mate is bringing over a vac bleeder so will sort it properly tonight.
  6. MadG
    MadG New Member
    That's what I would have done, but then bleed conventinally, ie on /off, open nipple / close nipple.
  7. Hudson
    Hudson Active Member
    Did you manage to sort this out ?
  8. Mr OCD
    Yep... All done :)
    Got a vacuum bleeder to do it ... 2 min job then.
  9. Hudson
    Yep, got one of them myself.... mittyvac mv8550, should make the brake/clutch fluid change a lot quicker and simpler.
