Front brake is working ok, but not operating the rear brake light. The switch seems ok. I can hear it click when I pull the lever and again when I release it. I have recently changed the front levers. What could I of done wrong?
Have you checked the connectors are the right way round? Or possibly the contacts have got dirty try some contact cleaner
It was only bolt off / bolt on, I've not taken any contacts off. Will have a look Tomoz when I'm off work- rear brake peddle works fine
Well got home, jumped the two wires & the brake light comes on. So the switch must be faulty, Does anyone know if its a sealed unit or can it be gotten into ?? There is a switch on Ebay so might have to look into that one
Viewed a handy video on YouTube, i took the switch apart and cleaned both sides of the affected contacts back Brake light now working okay, many thanks for all the replies
Nice pic of the 954 in your avatar, mine is the white/blue but i do have a soft spot for the yellow/black on the RR3.
