Rear brake noise
Discussion in 'General 1000RR Discussion' started by Tony Burrell, Mar 24, 2020.
  1. Tony Burrell
    Tony Burrell Active Member
    Hello I have a blade rr6 and I have noticed at low speeds my rear brake makes a fog horn sound.
    Any ideas what may be the problem
    Thanks Tony
  2. Selmer50mark
    Selmer50mark God Like
    When does it make the sound , when in use or not
  3. Tony Burrell
    When using it
  4. Selmer50mark
    Probably just the noise it makes because its gripping the disc , check everything is ok with caliper, ,, like mounting bolts and the pistons clean
  5. Tony Burrell
    I thought it was the pads so I bought disc and pads .
    Might just give them a good clean up and see what happens.
    And send the discs and pads back
  6. Selmer50mark
    Never noticed the noise on my RR7 because I only ever give the rear a dab if I go in to a corner to hot to help pull her round
  7. Tony Burrell
    For some reason I got into a really bad habit of using alot more than I should.
    Cause prior to this it was fine
