rear brake pressure switch.
Discussion in 'Mods, Upgrades, Accessories and Products' started by jamie meads, Jul 4, 2015.
  1. jamie meads
    jamie meads New Member
    I need to get a rear pressure switch for my rearsets. what size do i need? most are m10. but then the second measurement is either 1 or 1.25mm i dont even know what this number is for? and they dont specify the length? thanks j
  2. sps170373
    You need m10x1.25 for a honda master cylinder, m10x1 if you have brembo
  3. jamie meads
    Thanks bud
  4. t0m541
    t0m541 Senior Member
    The second number is thread pitch, how far apart the screw thread are...
    M10X1 = 10mm bolt hole size with the threads 1mm apart, M10X1.25 = 10mm bolt hole size with threads 1.25mm apart
    The higher the second number the coarser the threads will be..this goes for all bolts etc..
    Hope this helps
