Rear brake
Discussion in 'General 1000RR Discussion' started by Swty, Aug 26, 2019.
  1. Swty
    Swty New Member
    I was riding my bike today 2009 blade non abs when all of a sudden the back locks up just two minutes earlier I had pulled over and it was fine.
    I couldn’t push the piston back in the calliper until I loosened the banjo bolt for the flexi hose at the top of the master cylinder.
    So looks like master cylinder rebuild time.My question is anybody else had this should I look at changing the master cylinder for a better one.
    Many thanks
  2. Bikeboy
    Bikeboy Active Member
    Make sure your pedal is free and returning fully. It only needs to stick a little to prevent the return of fluid to the master cylinder
