Rear footpegs removal
Discussion in 'Mods, Upgrades, Accessories and Products' started by Edinburgh Bladerunner, Aug 1, 2014.
  1. Edinburgh Bladerunner
    Hi guys, just wondered if anyone has managed to remove the rear footpegs on a 2014 ABS Fireblade??
    2nd attempt now but stuck on what i think is the ABS module and not sure if it can be done.
    Any advice or tips?
    Cheers
  2. M3NTALIST
    M3NTALIST New Member
    I've not done it on a abs version but was just wondering which way your doing it as there seemed to be two ways of going about it when I was looking into it, so thought you could maybe try the other way. Some said to remove the battery, electrics and undertray (I think). I went for remove the tail unit and split the rear subframe in half which seemed the least likely to run into complications way, took about two hours but reckon I could do it in an hour now.
    Hope this helps.
    Andy B
  3. sps170373
    Splitting the sub frame is the easiest way in my opinion, first time takes about 2 hours and just be patient
  4. Remal
    mines a 2011Abs blade and I have it down to about 30 mins splitting the rear frame. been apart a lot for track fairing. lots of info on here about it. Search for it and you will get lots of feedback. it cannot be much different to mine I would have thought
  5. Edinburgh Bladerunner
    Cheers guy, i found that removing some plastic, lock and undertray, then removing one side of the subframe at a time, i managed it in just over an hour.
    Looks much better.
    Ta
