Rear light with integrated indicators
Discussion in 'Mods, Upgrades, Accessories and Products' started by Joeys boy, May 20, 2014.
  1. Joeys boy
    Joeys boy Active Member
    Has anyone fitted one of the above? Iv bought one for my 2010 blade and its came with 2 resistor blocks i'm a little unsure of how to wire it up any pics would be greatly appreciated. cheers
  2. ColinBR
    I wouldn't bother with the resistor blocks mate as they at times can fail and also heat up a fair bit.
    You can get a indicator relay that plugs in behind the nose fairing that let's you use LED indicators.
  3. Joeys boy
    If I use a new relay will the front indicators still flash at the correct rate? Cheers
  4. ColinBR
    Yes they will flash at the correct rate. It's what I have done
  5. Joeys boy
    Cheers were did u buy ur relay from?
