Rear shock - am I going crazy
Discussion in 'Mods, Upgrades, Accessories and Products' started by SimonT, Apr 20, 2015.
  1. SimonT
    SimonT New Member
    I have just fitted a new k-tech DDS rear shock but its touching the swing arm near the top of the swing arm.
    I'm positive I have fitted it as the workshop manual and the picture of the old shock - can anyone advise?
    Cheers
  2. ColinBR
    Is that triangle the correct way round mate. Ie the linkage?
  3. SimonT
    SimonT New Member
    I am sure it is - the first picture is the original, the second is as it is no and both look the same and as the workshop manual.
    I can only imagine the shock is a different length or K-tech sent me the wrong one!!
  4. PeterT
    PeterT Active Member
    Soon as you put the weight back on the rear subframe and bike it will correct itself, it is touching because the rear is at it's longest droop.
  5. PeterT
    Triangles are correct, did you measure and adjust the new shock to the same length as the original?
  6. SimonT
    SimonT New Member
    I just tried that and its still touching. The k-tech shock is a lot wider at the top than the stock one.
    I'll have to bell them in the morning.
  7. graemewalker
    graemewalker Elite Member
    It definitely looks like they have sent wrong shock to me should be play on sides check part first sure that will be the case
  8. SimonT
    SimonT New Member
    Fair play to k-tech, they rang me this morning without having to be chased and are sending a courier to collect this afternoon.
    Things go wrong in life but its how people deal with rectifying the problem and I am more than pleased with their speed of action
  9. sps170373
    So did they realise their error without you calling them?
  10. TheRamJam
    TheRamJam Well-Known Member
    That's great service from K-Tech.
    While you're waiting, order up some tasty Ti linkage bolts too
  11. SimonT
    SimonT New Member
    I sent them an email late last night.
  12. sps170373
    Ah ok! Good response on their part and hopefully resolved very quickly
