Rear sprocket washers
Discussion in 'Mods, Upgrades, Accessories and Products' started by Swadnod, May 13, 2023.
  1. Swadnod
    Swadnod New Member
    Guys , I've fitted a new supersprox rear sprocket and my only concern is that the 6 bolts that hold the sprocket on,the thread doesn't seem to clear the nut by much,has anyone fitted an aftermarket sprocket and not bothered with the washers ?, mine are fitted at the moment and nuts torqued up correctly.
  2. Swadnod
    Swadnod New Member
    It's a 2021 RRR-sp
  3. Jez
    Jez Senior Member
    I would say as long as the thread is through the nut it will be ok
    • Agree Agree x 2
  4. Broadie
    Broadie Active Member
    The lock piece is on the thread. Tbh don't remember ever seeing washers on a rear sprocket. Is it because it's aluminium?
  5. Selmer50mark
    Selmer50mark God Like
    Looking at the pic all looks good
  6. Jay Floyd
    Jay Floyd Active Member
    Mine is the same after fitting Sitta Sprocket, use thread lock and all ok :) 2020 RR-R
  7. Ritchierich
    Ritchierich Well-Known Member
    I replaced mine and used ProBolt titanium nuts, plenty of thread protruding. IMG-20230205-WA0000.jpeg
  8. buz
    buz Active Member
    The lock tabs are not in the threads. The nuts have flanges so what are the washers for?
  9. Ritchierich
    locked bit is 1 thread in and washers are to spread the load of the nut against the sprocket.
  10. buz
    buz Active Member
    1 thread in is not enough as they are still on the taper.
    The flange nuts have washers built in. That's the flange.
