Rear Sprocket
Discussion in 'Maintenance' started by Milky, Aug 25, 2011.
  1. Milky
    Milky Active Member
    Bit of advice. Heard that you can fit 42 T rear sprocket instead of 40 T to 2005 Blade to give a bit more low down grunt. Speedo will not be accurate, but by how much mph wise ??:help:
  2. dan.1moore1
    10 MPH ish
  3. Remal
    sorry off topic but made me think of this
    Sean Connery's agent calls him up and says: "Sean, I've got you an audition tomorrow morning about 10ish"
    To which Sean replies "Tennish? I don't even have a racquet"
  4. flatstickHRC
    flatstickHRC Active Member
    There is a calculator on the healtech speedo healer website.
    I don't think +2 teeth will affect it that much.
    The figure will increase/decrease depending on your speed but I would expect around 3-5% difference.
    The speedos are a mile out to begin with anyway so wouldn't worry too much.
    #4 flatstickHRC, Aug 25, 2011
  5. Brym
    Brym Active Member
    Rough guide would be about 10% over reading. I did that on my old GSXR and factored it in if i rode past a speed camera etc to be sure never had a problem. And as said they are a bit out as standard anyway
  6. djfleming22
    djfleming22 Active Member
  7. flatstickHRC
    Right here we go
    The speedo over reads by 5% as standard
    With a 55 rear tyre it over reads by just 2.3%
    Go up 2 teeth on the back to a 44 on a 50 tyre and speedo over reads by 9.5%
    Go up 2 teeth with a 55 rear tyre (which I have) and speedo over reads by 6%
    So up 2 teeth on the back with a 55 tyre gets your speedo more or less back to where it was when it left the factory
  8. flatstickHRC
    Masher if you fit -1f +2r on a 50 tyre you will over read by 15% or 12% with a 55 tyre
  9. Milky
    Milky Active Member
    Thanks for advice folks defo something I'll consider when I get it back
  10. dan.1moore1
    So my 55 tyre with standard sprockets will be out ? Good enough excuse for me to go up 2 teeth i reckon lol
  11. flatstickHRC
    Well yes and no
    The standard speedo has a 5% over read built in
    So with a 55 tyre it reduces it to just a 1% over read so your actually more accurate with the 55 tyre.
    Fitting a 44t will take it back to 6% so roughly back to standard speedo reading.
  12. Jamiestrada
    I have a 55 rear so Going +2 on the rear sproket then, and I dont have to spend £80 on a speedo healer like I did on the R1
    Result !
    !!!UPDATE!!!
    Just got a 44th 530 sprocket from Talon in yeovil Anodised gold for £30, so will be fitting that tonight, then hope it stops raining !
    #12 Jamiestrada, Aug 26, 2011
