Rear tyre
Discussion in 'General 1000RR Discussion' started by bladeaddict, Oct 2, 2016.
  1. bladeaddict
    bladeaddict Active Member
    just checking my pressures before a ride out today
    Noticed rear tyre
    Covers about half the circumference. Wasn't there a week ago before last ride.
    Safe to use?
  2. Iain
    Iain Active Member
    No, get a new tyre you numpty!
  3. sps170373
    Nope new tyre time! If stopped you'd get points and a fine minimum
  4. Barstewardsquad
    New tyre and check your hugger.
  5. SimonRR
    SimonRR God Like
    New tyre, not safe or legal :eek:
  6. poppy72
    poppy72 Active Member
    Hugger for sure,
    Sent from my GT-I9505 using Tapatalk
  7. RepsolPaul
    RepsolPaul Well-Known Member
    There's loads of tread on the sides and there's another 3 mm of canvas to use.
    Man up and ride it.
    Are you joking even posting it ?
    It's NFG,
  8. sps170373
    Hugger wouldn't do that it's just wear! It's way past the wear indicator shown in the photo
    More likely is wheel balance is off hence wearing more on one side
  9. bladeaddict
    Left bike at home and used sons KTM, lucky just returned to Uni.
    Cannot believe how squared off the tyre is. Nearly all the miles where done on flowing A and B roads.
    Is this a common theme with Sportsmarts ?
    #9 bladeaddict, Oct 2, 2016
  10. Barstewardsquad
    The hugger wouldn't, but something stuck between in and the tyre might :)
  11. Singh1000RR
    Singh1000RR Active Member
    My Pirelli Diablo Rosso2's did exactly the same. I think its a common trait on the softer "more sporty" road tyre.
    The middle section is meant to be harder rubber on dual compound tyres but they still go soft and start to tear.
    I still did a few miles on them - but as has been mentioned above I don't think its legal.
  12. Slimwilly
    Slimwilly Member
    Yep,normal, Metzelers go the same
  13. SimonRR
    SimonRR God Like
    What rear pressure you running?
  14. danthorrr4
    danthorrr4 Active Member
    Normal here too for the Rosso 2's. That's just the wire starting to show once its very worn. Best replace it, way past its best.
  15. bladeaddict
    36 front 40 rear
  16. Jimbo Vills
    Wow that's high isn't it??
    Seen loads tyres do that on tour (including mine, and one not on tour :oops:).... Your about 100 miles shy of a puncture IMO. Wires will be through in no time.
    I'd ride that to tyre shop that's local and that about it. At which point he will tell you to hang your head in shame ya tight wad lol
  17. sinewave
    Run 36/36 on my Sportsmarts on the Gixxer, look Mintedy Mint!
  18. bonjo
    bonjo Active Member
    I only do road riding and the wear on my old tech pilot power is pretty even (I do not do much motorway or straight roads). Run 36/40.
    Possibly you spun the rear tyre out of or during cornering which overheated it momentarily and melted that part. Is the tyre dual compound?
    the wear indicator is I think at 1mm. If your tyre treat depth is below the legal limit (middle or sides) then you can get a fine for it but in case of an accident claim, can also create with your insurance
