rear wheel chocks (or any ideas?)
Discussion in 'Mods, Upgrades, Accessories and Products' started by bash1k, May 9, 2015.
  1. bash1k
    bash1k Active Member
    Does anyone use one / have one that can fit the blades rear wheel? I have moved house and now have to park my bike in a very narrow brick building (about 1.3m wide) so I plan on wheeling the bike in backwards into a rear wheel chock as I can't fit the bike and me side by side, nor can I put the bike on it's side stand. But I can't find a chock wide enough to take the blades rear wheels. Any suggestions?
  2. Kris
    Kris Active Member
    Never heared of such a thing. Why not put the bike on a rear paddock stand and push it in?
  3. Cbrjay
    Cbrjay Well-Known Member
  4. Cbrjay
  5. bash1k
    Mate this is perfect! Thank you very much, appreciate this. I could only find rears that would take a max 180 rear... this is spot on :)
  6. Cbrjay
    No worries mate
  7. Cbrjay
    I've not used the company mate, so don't know what they are like to deal with just found it on Internet
  8. Cbrjay
    Did you get sorted in the end?
  9. bash1k
    I did mate, and it didn't involve a chock in the end. After measuring up I was left with 45mm with the bars turned on full lock to allow the door to shut, so with a chock it simply wouldn't work. I've since fixed rubber matting to the inside of the walls and I now simply wheel the bike in backwards, turn the bars on full lock and rest it on the rubber walls. As you can imagine, the space is tiny!
  10. Cbrjay
    Happy days, it's works tho
  11. bash1k
    Yep works a treat
