Rearsets for abs
Discussion in 'Mods, Upgrades, Accessories and Products' started by poppy72, Aug 9, 2016.
  1. poppy72
    poppy72 Active Member
    Help! can anybody recommend rearsets for 2014 abs with akrapovic fitted
    Sent from my GT-I9505 using Tapatalk
  2. sinewave
  3. poppy72
    They look pretty cool do you have these?
  4. sinewave
    Had 2 sets of these on 2 diff Bikes, highly recommended Italian Bling which Crash well too! :rolleyes:
  5. poppy72
    Is there a fitting point for a akrapovic megaphone exhaust? Do the use standard master cylinder and brake light?
  6. RazorBlade
    RazorBlade Member
    I have run Vortex on both my blades. The current one is a 14 abs model. Keep in mind that you normally have to replace the rear brake light switch with an inline brake pressure switch. Opening up the abs lines is like opening up a can of worms so I opted to run them without a rear brake light switch. If needed for rego I can rig up the stock switch to work but it's pretty dodgy.
  7. poppy72
    Yeah I was hoping to use stock brake light etc don't fancy opening stuff up, I had gilles on my 600rr with stock master cylinder etc worked a treat well made etc
