Red reflective sticker strip
Discussion in 'Mods, Upgrades, Accessories and Products' started by JM1, Oct 27, 2013.
  1. JM1
    JM1 Active Member
    I need a red reflective sticker, not a plastic reflector or one of those round ones. It has to be the flexible sticker type. I got some with an R&G tail tidy once but have used it all.
    Anyone know where I can get some please?
  2. Nutty Tart
    Nutty Tart Well-Known Member
    Have you tried fleabay ?
  3. sps170373
    What do you need it for?
  4. JM1
    JM1 Active Member
    Yes.
  5. kpone
    I've used 3M heavy duty prismatic tape in the past and it's got something like a 5 year life. Unfortunately you'd probably need to but a whole roll, but it's relatively easy to get hold of.
  6. JM1
    JM1 Active Member
    Thanks kpone I'll maybe try the 3m stuff
  7. r1monkey
    r1monkey Active Member
    how much do you need ? i work as a hgv mechanic, new trucks now have to have red reflective tape on the rear of them , pretty sure i have some in the garage , if not ,i can get an off cut from work.
  8. phantom
    phantom Active Member
  9. r1monkey
    why not ? it is fitted on trucks for mot now, you only need a tiny red reflector on rear of bike for mot test.
    that is the same as the stuff i can get so if jm1 wants some let me know ,you can have some for nowt.
  10. JM1
    JM1 Active Member
    Thanks very much mate, but I've already bought some now :)
  11. JM1
    JM1 Active Member
  12. phantom
    its in the rules
    1.5 Reflectors
    This inspection applies to the obligatory rear reflectors that are required by Regulation to be fitted.
    Rear reflectors are not required to be fitted to vehicles used only during the hours of daylight, which are fitted with neither front nor rear position lamps, etc. (See 1.1.A)
    Approval marks are not included in the inspection.
    Reflective tape is not acceptable as a substitute for a rear reflector.
    in good working order
    Note: At least 50% of the reflecting surface must be visible from the rear
    red in colour.
  13. ShinySideUp
    ShinySideUp Elite Member
    Cars, vans and trucks also have red reflectors built into the rear light clusters mate.
  14. JM1
    JM1 Active Member
    Cheers Phantom, but that's one rule I don't mind testing out.
    I'll take a real reflector with me and stick it on if he wants (in 2 years when MOT's due) :)
