Remap after full system
Discussion in 'Mods, Upgrades, Accessories and Products' started by Punisher5964, Sep 26, 2016.
  1. Punisher5964
    Punisher5964 Active Member
    Dudes, I have a 2013 blade with a Carbon Yoshi and a few other bits, I am looking to maybe go with a manifold as well for a little extra power and noise.
    Will i need a remap to run a full system and if so do i need a PCV or can the standard ECU be mapped?
    Also do I need to stick with Yoshimura or will any aftermarket manifold fit with my current exhaust?
    TIA.
  2. Punisher5964
  3. Scott
    Scott Active Member
    Wouldn't bother with a manifold if it was me. But I would go get a decent map. Either use the ecu re flash by the rb engineering that get regular good reviews. Or get a pc/bazaar fuelling control and get it mapped by a mapper of your choice close to u. Always good recommendations around your area. If in Essex if used race engineering dunmow and in Norwich iv used track electronics. Both iv been very happy with
  4. Punisher5964
    Thanks mate, I will look at RB engineering, they're only in Wakefield which is where I work so could be perfect.
    Thanks.
  5. stupot
    stupot Active Member
    Rich (RB Engineering) is in Gloucester.
    Top bloke to.
  6. Punisher5964
    Oh yeah, google brought it up but also found me R&B Engineering which is near me. Rubbish.
  7. callumw
    callumw Active Member
    The stock manifold on the blade is pretty decent, but if you swap it with an aftermarket one (e.g. Akra) then you're changing the power profile to make it deliver more at the top end, but as a result it'll rob power from the low/midrange.
    If you do do an exhaust swap, then it's worth getting it mapped in it's final configuration so it doesn't run the engine lean.
    >3 years ago I fitted a PCV on mine at the same time as my exhaust and downloaded the baseline map Dynojet had for my setup (Akra race slip-on & K&N), but it was running too rich at the bottom end. I could smell it over fuelling while sitting at traffic lights :)
    So I took it in to a local service station which also has a Dyno and got a custom map ... and it's been 100% ever since :)
    In fact ... here's a post about the process with charts and a link where you can download my custom map (at your own risk)
    http://1000rr.co.uk/threads/pcv-map-dyno-charts-and-suspension-setup.10182
  8. Punisher5964
    Thanks Callum, I had my last Blade put on the Dyno with a PCV and it was running lean, hunting for revs all the time so I didn't bother this time round. I'll probably just leave it now, just fancied the noise and grunt of a manifold but people are reckoning its not worth it.
